Trim Tab Fluid
Solittle
I noticed that the reservoir for one of my trim tabs is a bit low. What kind of fluid does it take?
Bob_VT
Re: Trim Tab Fluid
Hydraulic jack oil works just fine.<br /><br />Bob
Jack Shellac
Re: Trim Tab Fluid
Well, DEXRON II ATF would be my choice unless the maker specifies something different.
mikecjn
Re: Trim Tab Fluid
My boat has Bennett trim tabs and the owners manual for them says to just use Automatic Transmission Fluid.
Solittle
Re: Trim Tab Fluid
Thanks to one & all. I think I will go blindfolded into the garage and grab the first thing I touch.
Tabman II
Re: Trim Tab Fluid
SoLittle,<br /><br />I am Thomas and I work for Bennett Marine in the Client Service Department.<br /><br />If you have a Bennett Marine trim tab system, please use Automatic Transmission Fluid (ATF, any type and you can even mix it if need be). Fill it to 2/3-3/4 full and you should be ready to go. In fact, if you will provide me with your mailing address (trimtabs@earthlink.net), I will be happy to send you an ATF Funnel Cap at No Charge to help out!<br /><br />I look forward to your reply.<br /><br />Sincerely,<br />MJ Thomas<br />Bennett Marine, Inc
Cliffman
Re: Trim Tab Fluid
I have a Volvo Penta GI 5.0 in a Glastron CC. My Owners manual states to use "Volvo Penta DuraPlus Power Trim/Tilt and Steering Fluid". I don't think this stuff is something I can find at my local auto parts store. Does anybody know if I can use another fluid and if so what brand and type. Thanks in advance.<br /><br />Cliff
