Trim Tab problems. Up but not down ??
hey guys New guy here !!
I have a Chaparral 1800SL ( 1991) with a 3.0LX 135HP. Mercruiser motor and outdrive alpha 1 gen 2 I believe
I just De-winterized my boat and noticed my trim (tilt) switch is acting up. It will go up but not down. It was twitchy going up sometimes but goes up none the less. When I hit the switch down it just clicks once at the pump.
I am wondering if I can just order a new switch. I doubt anyone will have a switch for my boat just sitting on their shelves.
I took the shifter panel off to get to the switch and noticed the wires didn't have good connections. I cleaned the connections off and resoldered the wires and still no difference.
I am wondering what you guys think I should do??
infideltarget
Master Chief Petty Officer
Re: Trim Tab problems. Up but not down ??
Welcome to iboats!
If you hit the switch and it clicks at the pump, it ain't the switch. It's the pump.
but why would the trim go up but not down. If I get lucky I can get the switch to go down. It might go down once out of ten times hitting the switch down.
Ahh I hate crappy boats
achris
More fish than mountain goat
Do you have a service manual with a wiring diagram?
The up and down circuits are quite independent. there is a separate solenoid for each and the pump motor has 2 windings, one up and other down...
One thing I noticed too, I was at the boat twice. The first time I saw the pump tank was empty, thats when the down action didnt do anything. I went and got the fluid, re-filled it, hit the switch and it went up and down. Now a week later I still have fluid but no down.
infideltarget
or the solenoid.
Yeah, but I figured if it was "clicking" then the solenoid was making that noise, and therefore doing its job.
Is this system self bleeding? If not, If it was empty it may need the air bled from it, or if it was run dry, it may be time for a new pump.
achris
Even if the solenoid clicks it can still be faulty with bad internal contacts. The system is basically self bleeding...
infideltarget
Tru-dat. Good for him its self bleeding. Looks like its time to break out the Fluke meter, and take some voltage readings.
so where should I start. Is there a check list?
The trailer up button works. Or I guess it did its all the way up now so I can tell. But the switch just feels like crap to me.
bruceb58
You can swap the relays and see if the problem moves with the relays. If it does, you have a bad relay.
where would the relays be?..
Could I just take the wires going to the switch and just swap them?
LilRedNeckGirl
trim tabs, Arnt they like rain gutters on a house? we are all told they are essential, then we spend a fortune installing them, and alas, they never ever work properly. and then, eventually, we get pissed n off enough to rip them down, and have that epiphany, where the light bulb goes on, realizing properly trimming the drive, proper loading of the boat, and wala, all is well.....
