Trim Tab zinc anode
anaise500
I, own a tohatsu 70hp.
I would like to adjust the trim tab, (Zinc Anode) the one at the lower part of the outboard.
Trying to do so i failed , since apparently it is stuck.
Any ideas please?
walt-oxie1
Re: Trim Tab zinc anode
I usually drill a hole in the outer part of the anode and use a punch and hammer to try to turn it. So far it has always worked.
Sea Rider
When old anode is out, clean crew & tail threads with acrylic thinner to remove salt, and grease screw with salt water grease when replacing new tail anode.
Happy Boating
