Re: Trim Tab
That is actually two things, most important it is a zinc annode. I see lake, but if ever in salt you want it to control corrosion....also if you have a skinny draft on hull(fast) then you will find the torque from prop is pulling your boat, probably to left and you have to counter steer....at speed it'll be worse.
