trim/tilt 1987 force help locate fluid cap
foodfisher
Re: trim/tilt 1987 force help locate fluid cap
Below the motor, on the pump body (you can see the division) is a ferreled plug/cap. That's the fill..
jerryjerry05
Screw /cap on the side of the pump housing.
hays
Thanks man. I had so much paint on the pump it looked like a pimple under skin. Thanks again.
