Trim tilt 94 force 120
Tday1
I replace my trim motor and can here the motor when I hit the switch but the motor will not lift but it will pull it down then it's down its locked down until i loosen the line and lift manually and fluid comes out wondering if I'm doing something wrong or if something else is wrong bought this boat on auction and don't know its history just trying to get it out this year any help is appreciated thanks
jerryjerry05
You can have 2 different pumps on your motor.
Try to add a pic. Shutterfly or photo shop will help load pics.
After 3 post you can add them.
Does the motor run when the switch is operated in both directions?
Try swapping the wires around?
