ryno1234
- Dec 8, 2014
- 144
Disclaimer: this is for a Yamaha Stern Drive, but that forum isn't perused much and this is likely a generic question that would benefit any brand of outdrive.
My trim motor is not longer functioning. I tested the "up" and "down" relays per my Clymer's manual. Both relays "click". They also both show voltage as they should when pressing the desired direction. So, from what little I know about electrical, that means they're both working.
Here is what's interesting: The "down" relay showed voltage from the pump when I pressed both down on my control AND up. That really caught my attention. I then tried to test the "up" relay to see if it would show voltage while pressing both up and down on my control.... sure enough...
So, I would imagine if both the up and the down wires into the pump are receiving positive charge, that would definitely be at least one reason why the motor isn't working (right?). Also, since the relays themselve are isolated devices, I believe the continuity bridging (excuse the, most likely, wrong terminology) is happening inside my pump unit itself. Maybe something fused together?
One final note that may apply - I have had issues with my pump reservoir overflowing at times due to a cracked reservoir cap. This means that occasionally I'll have pump fluid run down the sides of the pump (sometimes a lot of it). The electrical connections go into the pump underneath the reservoir. I'm wondering if the liquid is acting like a conductor and may my electrical connections are just simply submerged in a lot of fluid.
Any ideas? I'm wondering if I need to purchase a whole new pump or if I should take my changes at disassembling this and figuring out if that is what's going on.
For reference, this is what the trim / tilt pump looks like: https://www.youtube.com/watch?v=5udslFA4J4M
