I'm having a problem with the trim going up but seems to do fine going down.
M marcus e. Recruit Joined May 3, 2003 Messages 1 May 5, 2003 #1 I'm having a problem with the trim going up but seems to do fine going down.
K KennyKenCan Commander Joined Aug 26, 2002 Messages 2,501 May 5, 2003 #2 Re: trim/tilt problem on 95 merc 60 Raise motor all the way and check fluid
S sharkcat Petty Officer 1st Class Joined May 4, 2003 Messages 285 May 5, 2003 #3 Re: trim/tilt problem on 95 merc 60 Is the trim working one way & not the other?<br />If so try swapping the relays if it now works in the opposite way the fault is in a relay.
