GMTK
- May 27, 2016
- 164
New to the forum, tons of great info here. Bought a 2004 Hurricane with a 4.3 volvo penta and 80 hours on the boat. Boat ran great until today. Trim/tilt is dead. I've spent the last 4 hours on this site and tried a bunch of the advice. When I hit the switch I don't hear anything at all. Fuse is fine. I tried running jumper directly to the blue and green wires from the battery and when I hit the positive side I got a really bad spark and wire starts to melt on the terminal on the battery. Motor didn't turn at all. I also tried one of the troubleshooting threads by pulling off the relays and checks the voltage in the relays. I got 0 on everything. I did make sure my power switch was on at the main console.
I took the motor apart and it had tons of corrosion. I cleaned it up and put it back together and then got the jumper wires back out again and again, really bad spark (but it did turn a little).
Going to replace the motor (if nothing else, due to the corrosion). Any other ideas on what I should do?
