Trim/Tilt Pump
LuckyPenny
A friend of mine has offer me a trim/tilt pump and the question came up if it had the reverse lock built into the valve body or had a seperate reverse lock. Can anyone tell from the part number?<br /><br />Part number: 45060A18<br /><br /><br />Thanks
Re: Trim/Tilt Pump
Part # Doesn't Help Me.........<br /><br />Tell Me what it Looks like..........<br /><br />What Size are the Threads for the Fittings ????<br /><br />The 1 for the seperate lock has a lightweight plastic tube,+ a compression fitting on the return side.........<br /><br />The Others have 1/4" Brakeline Fittings on Both sides........
LuckyPenny
Re: Trim/Tilt Pump
Thanks for the response. I have no idea about the hoses. It is out of the boat. That is why I was hopping the part number would help. My present system has the seperate reverse lock. I think it would be nice if this pump had it intragrated, one less part to fail.
Re: Trim/Tilt Pump
Look at the Fittings on the bottom of the Pump,........<br /><br />I've Already explained the Differences......<br /><br />If by chance it's the pump with 2 lines that Are the Same,......<br />You can Convert it,+ Get Rid of the seperate Lock-down.........
