Re: trim/tilt question
Bassfshr, The slide out pin only controls the trim of the motor (the tilt angle of the foot of the motor). The different heights of the motor means moving the whole motor itself up or down on the transom, most boats will attain a higher speed if the anti ventilation plate is about 1" or higher above the bottom of the boat instead of even with the bottom of the boat because it reduces drag from the motor itself.
H
