Trim-tilt&sender replacment
D_J_Winn
97 Bravo III mercruiser LX
Is it possible with thru hull exhaust just to remove the one (hard to remove) bolt holding the retainer plate? (the one sealing the trim wires in place as they pass into the boat). Is that the only bolt holding them in place?
By doing so will i be able to remove the old sender and limit and replace with new ones....Iam asking because i can see the bolt and that seems so much easier.
I know, I know...
Thank you fellow boaters
Bt Doctur
Re: Trim-tilt&sender replacment
manual shows 1 bolt holding the retainer in place so it you have access, go for it.
