Trim/tilt sensor wiring question
Flyinb
replacing the trim sensor's on my outdrive and the new ones i received (Quicksilver) are not color coded. So i guess it's a 50/50 chance i get them right. My main concern is if they are hooked up backwards will it hurt anything while i am figuring out what way they go. I know what sender goes where just not the polarity of the wires.
Thanks,
Bruce
nikon
Re: Trim/tilt sensor wiring question
You can't hurt anything. Besides, you can't hook them up backwards with the quick connectors they come with. One wire is male, other is female.
Flyinb
Actually the connectors on these are the same, both male. Well i hooked them up adjusted and all is good, must have got lucky first time around :)
