jakehorton15
- Feb 16, 2014
- 66
I’ve got a 1994 Johnson faststrike 150 model j150glera
When I raise the motor to leave for the lake after it’s been sitting for a week or so the trim and tilt are very sluggish. It raises but very slowly. And it’s the same speed from all 3 trim switches around the Boat.
I raised and blocked the motor and opened the resivor cap and good clean fluid came running out immediately.
The odd odd part is after I’ve been boating all day and pull it out of the water it raises fast like it should both up and down.
I can also also spray silicone lube around the trim rams when out of the water and it helps speed the rams up and down. It also bounces a little when lowering for the first time when launching. Could some of the pins that allow it to tilt up and down be sticking until they get wet or the trim seals be dry and creating friction?
Thanks for any help
Thanks for any help
