trim/tilt switch relay
coastsider
OK, tried to reset upper and lower stops on my dp-s outdrive after hunting down instructions for the v/p#3851584 trim limit control kit installed on transom, after I found one of my batteries pushing against it and activating the led's. I was looking forward to getting accurate reading on dash gage, to better trim the boat. I went through procedure but found my "Beebe" dashboard trim indicator not listed on the setup/calibration table, and now I can only get outdrive to go both ways with the unit in the "0" gage position. I was looking forward to having outdrive stop before it goes past level, or at least being able to see position on gage. It never seemed to be very consistent, since I bought boat a year ago. Any advice?
Don S
Re: trim/tilt switch relay
Does the sender work?
coastsider
Perhaps not. I need to get a friend that knows circuits over to check it out. Still, I'm curious which setting to position switch relay.
