trim/tilt upgrade
Hey guys, hope you all are doing well & had a great New Year. I'm looking to upgrade of the tilt system on my boat. It's a 1966 starcraft holiday with a Mercruiser 110 & a MC-1 outdrive. This system has a tilt only system & i have come to miss the trim feature. I'd like to upgrade the system to a tilt/trim system. Is this posible?
Nope,... I believe it's Way to old to up-grade, without major changes, as in a newer transom assembly,......
Post up some pictures of yer drive,...
fishrdan
^^^ Agree, sounds like you have a drive earlier than an MC1, (1A, 1B, 1C,?)
I doubt your transom assy has the plumbing and anchor points for tilt/trim rams.
The stamping says mc-1 A1 B1 C1
Ayuh,.... You've got a very rare drive, that parts can't be bought for,....
Like I said above, you'd need to swap everything aft of the rear motor mounts to up-date it,...
