Trim/Tilt... ...Water Pressure Gauge
singerjr
If you trimmed your motor up too much, to the point where you might not notice the problem from sound, would the water pressure gauge show a drop?<br /><br />How quickly does the water pressure gauge respond to lack of water?<br /><br />First water pressure gauge!<br /><br />Thanks ;)
Trent
Re: Trim/Tilt... ...Water Pressure Gauge
It responds pretty quick..You would have to raise the engine pretty high to lose water pressure. You need around 5 psi at idle and 10 to 15 psi at wide open throttle (WOT).
singerjr
Thanks Trent very much! :D
