Trim Tilt Wiring on Mercury 115 HP Tower Of Power
kingjoe
I have this 74 or 75 motor as a replacement for my Quantum boat.... There is a line coming out of the power trim that contains 2 white wires.... I have no idea where or how to hook these up so I can use it.... Appreciate any input.....
kingjoe
Thank you George..... Unfortunately that bracket and switch is missing.... Going to have to try and find a replacement.....
Chris1956
That PTT unit should consist of two trim cylinders, two trim brackets, 4 hydraulic hoses, a pump reservoir unit in the boat and a wiring harness and PTT panel. How much of it do you have?
Chris1956
The trim limit switch is not important, and most have probably broken by now.....
