Trim unit on a volvo penta sx
wellcraft jim
All of a sudden my trim gauge stopped working, any ideas on what to trouble shoot? The out drive tilt work fine.
rocky t
Re: Trim unit on a volvo penta sx
i had the same problem, first i checked all the fuses all were good, then i put on a new gauge, still had the problem, i had to replace the trim sending unit on the right side of the outdrive.
EAVES
Prolly the sender on the gimble ring
bajaunderground
Check all connections too? I had trouble with my 'up' went thru and checked fuses, connections and where the connect at the exhaust housing was pulled apart enough for the down to function but not up!
dypcdiver
Frequent problem that is usually a break in the insulation on the wires going to the underwater section of the trim sender, it allows water to get into the sender and short it out. In the first 8 years of this boat I had to replace 4 trim senders for that reason. New senders seem now to have a more flexible insulation, present one is in its 4th season.
Changing it out is a bit of a pain and can only be done with the boat out of the water, I did a write up of how to do it on this forum some time back, a search should find it.
Here is a link, post number 7
http://forums.iboats.com/volvo-pent...umber-my-trim-sending-unit-please-600213.html
bruceb58
Do yourself a big favor, save some money and don't bother changing it. The senders are notorious for failure. Just live without the gauge.
I will never change mine again.
