Hello All, wondering if anyone has any advice on this issue. Reading through the forums, I know this is a common issue on the Mercruiser alpha one's but I am having a bit of difficulty determining what the exact issue might be. So basically, the trailer function moves the out drive up and the trim down function does move the out drive down but the trim up function when you press the switch does not work at all. To troubleshoot, I have pulled the two wires coming from the trim limit switch and used a jump wire (in line test light) to verify if the switch itself is the culprit. When I press the button with the test light jumping between the blue and purple wires, the test light turns on but the out drive does not move at all. From my understanding, this would mean that the switch isn't the culprit since the light activates showing there is power and the switch is operating as intended when pressed; but the motor should be responding as well with it jumped but it isn't. Am I missing something or am I reading the forums wrong and troubleshooting incorrectly? I will take a closer through the manuals and electrical diagrams so I have a better understanding but thought I would ask everyone as well. Thanks in advance!
