OK, I've searched but not lucky enough to find the exact thing so here goes:
- Replaced a 24V Motor Guide Tour 767 (67# thrust) with a MinnKota Terrova 80# thrust
- Wiring coming from the two batteries are two seperate hots and two blacks going to the front of the boat. These are 6AWG.
- No selector switch. It's straight 24V with two individual 12V being jumpered to 24V at the plug.
- I currently have a 40A circuit breaker at the battery on each of the two positives that are going up front. MinnKota. of course, recommends 60A breakers for this trolling motor.
So my question is, with the two seperate 12V wires going to the front of the boat, wouldn't the amp draw be halfed? In other words, if the total amp draw is 50A and you have two wires supplying the power would that equate to 25A per wire?
I'm trying to decide if my current 40A breakers are good enough (if it truly is 25A per wire) or do I need to go ahead and chage over to 60A ones? I have new 60A ones already but I do wonder if 60A breakers are ok for that setup and 6AWG wire. I certainly do not want to put breakers on that are too big for the wire size etc. I did look at some charts but they all differed somewhat so I wanted to ask here too.
Thanks!!
Brad
Thanks!!
Brad
