Re: Trolling Motor Circuit Protection
My guess would be that the two fuses had to do with the 12/24 wiring, and maybe the prior owner converted it to 24V only. You need to trace out the wiring to be sure.
If you never popped the fuse when running full tilt, go with a 30 amp manual reset breaker (assuming 24V). From a rough order, thats right around what your 24V motor max draw is. Given your wire size, do not go higher than 40 amp breaker. I would place the breaker on the + terminal that feeds the trolling motor and you only need one.
