kiltedcelt
- Mar 17, 2012
- 8
I have a 12v 55# thrust Haswing trolling motor that I'm using on my 14' inflatable boat. I was trying out the motor yesterday trying to figure out what sort of battery life to expect based on run time. Anyway, I intended to use this motor as primary propulsion for the boat. Much of the three hours I was out I was running the motor I was on the highest output setting. At some point the motor must've been drawing too much current and the leads heated up causing the insulation on the positive lead to melt partially. The only other thing I can think is that maybe the connections of the motor leads to the battery may not have been secure enough? I have to admit I really don't know a whole lot about trolling motors so I may need some education on the matter. Can I use this motor as primary propulsion for extended periods at the highest setting, or should I vary the speed between lower settings and higher settings? Or, is this likely more a problem with the connection of the leads? The battery is a Group 27 AGM - Cabela's house brand. The bolts that came with the battery are 1/4x28 bolts that screw in, however the washers seemed to be a bit oversized compared to the diameter of the bolt, so maybe the connection isn't as tight as it could be, allowing the wire to somehow overheat? If this motor can't be used at it's max setting is there some other type of electric that can be, or is there something I can build myself? I'm open to suggestions and advice. A lot of the lakes and bodies of water that I like to go on, only allow paddling or rowing or electric trolling motors - no gas outboards. At some point I would like to get a gas outboard for use in other places but currently can't afford to buy new as far as that goes. Anyway, any suggestions, theories, advice?
