jtexas
- Oct 13, 2003
- 8,646
MotorGuide 3, 12V 36lb foot controlled. Whenever the pedal is in the full heel-down position, which is powerhead rotated completely to port, it fails to respond to the on-switch. Toe-down just a little and hit the switch, it starts, and then heel-down it keeps running. Just won't start spinning in that position.<br /><br />I checked the connections under the pedal, cleaned some corrosion off a couple, but symptoms persist. I'm guessing it must be inside the shaft?<br /><br />Has anybody disassembled one and lived to tell the tale? I'm a reasonably confident if not competent do-it-yourselfer with a working multimeter - just wonder if I'd be wasting my time to try & open 'er up.<br /><br />I'd be real sad if I had to buy a new trolling motor, even sadder if I had to fish without one.<br /><br />Any opinions?<br /><br />thanks,<br />jtw
