I have a 1992 ex120 34lb. thrust trolling motor by Nephune Technology. They seam to be out of business. Where do I find help for this motor?<br />It sat idle several years. Now it won't run until the prop is turned on. Can this be repaired without a lot of expense? Switch and electronic module seem to work fine. Propeller shift seems to drag at certain spot when turned. Thanks
