trolling Problems
jim4buzz
COMMENTS: I have a 1997 75 Force outboard Engine Runs at normal to higher speeds
great when the gas gets below or half full tank it won\'t stay idle without
pumping the primer ball. I installed a new fuel pump new hoses with clamps even
went between the fuel tank and the quick connector where I resealed that to. It
seem like a pressure problem I tried another portable tank with the same results
connecting it directly to the gas tanks. Where if any could this air loose be if
that’s the problem ran a decarb threw the system too.
