I thank y'all in advance for any help I will be getting!<br /><br />I have a problem wiht my '01 225 SSII. When cold starting the motor, it will crank but it will not start unless I put some carb and choke cleaner through the air intake. After this, it runs fine and it starts back again that same day w/ no problem. Next day I'm on to the same thing with the carb and choke cleaner. What could it be? I've checked on the fuel supply and it is OK....tried priming the bulb prior to start and nothing....tried the choke at the key switch and NADA...I'm getting kinda anxi...it is an SX225TXZ... Can anybody shed some light?
