I decided to replace the water pump impeller on my 1985 8hp Johnson. Everything went fine until it came time to put the gearcase back on. The trouble is getting the shift lever and spline to engage. There is a flat spot on the top of the spline and I am having trouble getting it in the right position. I am doing everything the manual says but it is not working. I can "feel" the spline right there when I wiggle the lever but it won't go into place. The manual says to put the flat spot fore and aft but it doesn't say which side. I can get the gearcase up all the way with the flat spot on the port side of the motor but this doesn't engage the lever. It just moves freely. I am lost.
