Trouble replacing grease fitting (video)
Florida
This is a lawn mower spindle; with a pressed in grease fitting. the old one got stuck in the coupler and pulled free from the aluminum spindle. I dont know how to press the new one in without deforming it. I dont want to remove the spindle from the deck because there is a high chance of twisting the heads off of the bolts that fasten the spindle to the deck. Any ideas on how to do this?
thanks for the help!
NoKlu
Re: Trouble replacing grease fitting (video)
Looks like there is a rim around the middle of the fitting? Find a socket that fits that rim and hammer it in. There is a tool for those fittings.
Florida
I broke the fitting! I called Napa, Sears, Advanced Auto and Tractor supply; no one I spoke to has ever eard of a grease fitting driver tool for pressed in fittings. I found a small socket that fit over against the shoulder of the grease fitting and started hammering. The shoulders on the grease fitting deformed and the grease fitting wedged inside the socket. :facepalm:
woosterken
could you drill it out,use a tap to thread the hole and put a bigger zerk in it?
woosterken
partskenn
woosterken
I agree, first thing that comes to mind is to run a tap through it, and thread the hole. Then just screw a new one in.
robert graham
If all else fails, use some JB Weld to hold it in place. Clean it real good with a wire brush and carb cleaner first.
Bob_VT
There are larger fittings and I would tap the hole and install a larger base fitting
NoKlu
A quick internet search and you will find lots of sources for the tool.
j_martin
It's a lawn mower deck spindle. They go to heck all the time and odds are there is one on the shelf at a reasonable price at the local co-op or lawn mower shop.
Twist off the bolts, throw in a new spindle with new bolts, get the lawn mowed, and quit wasting valuable boating time.
