dickie6319
- Jun 13, 2013
- 20
So i have a 1990 60hp vro that wont fire. After reading some post/replies I started at the emergency kill switch and referenced Clymer manual. The manual said to pull the 5 wire connector to the power pack. I located the connector and it has the same configuration that the pic in the manual shows BUT there is no wire going to the E terminal that they want me to connect the red lead of my tester to? There are only 4 wires. Im pretty sure its not the coil plug because that is the same configuration as the manual shows.
