I have a 1978 Johnson 70HP on a boat that I bought from a guy about two weeks ago. The man said this boat had been sitting for about 2 years but had been mostly rebuilt 3 years ago including the carbs. The first time I took it out I was left stranded because the starter went out. I changed the brushes yesterday and now it is spinning great. Last night when I tested it, it would turn over faily easy on the first turn. This morning I took it out and it took a couple turns but it started. After stopping and going a couple times I tried to start it and it just kept spinning. You couldnt hear any spark. After getting towed back I came home and changed the spark plugs and it turned over fairly quickly but it would die out after a couple seconds. Then I would keep trying to turn it and nothing would happen for a while. WhenI came back to it the same thing happened, It started up but it puttered out after about 7 seconds. Then as I tried to start it again you could hear it almost catch but it wouldn't and then it would keep on spinning. Another thing I noticed today when it was working was as I accelerated it would tend to stall, until I gave it a while to warm up. I'm not sure If I need to adjust the carbs or whats wrong. Any ideas would be helpful. 2 trips out and 2 tows back to shore, not very fun.
