woofer2609
- Jul 31, 2004
- 5
I am rebuilding a 6HP johnson model cd-23 (1965?)<br />There is a 115 lb compression reading in each cylinder.<br />The engine turns over smoothly.<br />There is a good spark at each plug.<br />The float bowl is full of fuel and the main jet seems to be clear. I took it apart and blew it out with air.<br />After pull starting a number of times and pulling the plugs, they are nether wet, nor do i detect any trace of fuel. <br />The engine won't even burble.
<br />I am so close to success that i can almost feel it! I have tommorow off, so if anybody has any suggestions, I could be running soon!
