This should be an easy one. I appologize for being a novice.<br />I just bought a boat with a 1989 175 Mercury outboard. I am having difficulty starting it. I am not sure if my procedure is incorrect or if I should look deeper into the motor. I prime the motor with the bulb until firm, pump the throttle 3 times, push in choke and hold and turn the key. If that doesn't work I try again, but maybe with out the choke, fearing flooding the motor. If that doesn't work, I try a combination of everything above. Should I keep pushing in the choke and hold in until it fires? I don't like giving it too much throttle, thinking it is hard on the motor revving so high right off the bat. Next thoughts are to replace, primer bulb and plugs, but I wanted to make sure my starting technique was correct. I would take any suggestions. Thanks<br /><br />I eventually get it running and seems fine.
