trouble with electric choke on 75hp brownband
Mercs and such
When i push my key in, i get nothing. I should be getting a "click" noise, which engages the choke solenoid. Now, i noticed that there is no connection to the key switch leading back to the choke solenoid. All i found was a snipped yellow wth black stripe tapped off to the block leading no where. I tried directly linking a length of wire from the end of the wire that was taped off, to the key switch. AND NOTHING :mad: IS THERE SOMETHING IM DOING WRONG? DOES IT HAVE TO LINK SOMEWHERE FIRST, SUCH AS A RECTIFIER/ SWITCH PANNEL??:confused:
ANY HELP WOULD BE GREAT. IM ON THE WATER FRIDAY, AND DON'T FEEL LIKE HOLDING MY HAND OVER THE CARBS. :D
MERCS AND SUCH
narvlebenoit
Re: trouble with electric choke on 75hp brownband
that wire should go to the solenoid and if that dont work i drilled a small hole throw the top cover with s.s. wire to the choke so i could pull it up to choke it.it works fine for a quick fix.
