Trouble with sea water pump on Regal
Shutto80
Hello again trying to figure out what's wrong with pump i can put muffs on with engine running and pull outlet side hose off pump and there's plenty of water circulating pull the muffs off and the water stops the impeller looks to be in great shape. We even put some sealer around the seal of the pump. Any suggestions gonna try try to put a new impeller tommorow
Don S
Re: Trouble with sea water pump on Regal
We need to know the engines full model number or serial number to help you. Type of boat means nothing in the engine forums.
