Trouble with System check? johnson 2002 40 hp
stefano71
Hallo,<br />i started my johnson 40 hp 2002 after changing water pump and after a four month period of inacticty. After several time the engine started.<br /><br />My problem is that the engine execute the system check, as normal, before start-up but after the engine started the system check run again (the system makes a second beep, the lights are relit and then they are turned-off in normal succession). The motor then works perfectly. <br />this is normal , or not? I had the impression that the oil did not arrive to the motor. I have cleaned up the tubes of the oil from the eventually presence of air, but the system check is behaved in the same way.
jegervais
Re: Trouble with System check? johnson 2002 40 hp
Bongiorno Stefano!<br /><br />Benvenuto a iboats.com! <br /><br />It is normal for the system check to re-cycle upon start up. If voltage drops below a certain level and is restored (such as during start up) it will do that.<br /><br />If there is a problem, the alarm horn will sound for 10 seconds, and the appropriate light will stay lighted until the problem goes away or is corrected.<br /><br />John
