I'm new to this forum. I have a 5.7 litre Volvo I/O that is giving me some real grief.<br /><br />The motor has 67 hours of run time on it, only used in freshwater, parked under covered storage in the winter.<br /><br />The problem I have is that I ran it at a lake the other day and it ran fine accept the idle seemed rough. After checking everything possible and cleaning out the carb it still acts like it's idling on less than all 8 cylinders. From 800 rpm to about 2000 it sputters and then it will smooth out all the way to 4000 rpm +. Even on the lake with or without a load it runs like this.<br /><br />I put in new plugs, checked the wires for any cracks or arcing, dist cap appears to be good. Fuel filters are clean. The only other thing I think that is possible is that I ran the tank down low on gas and I think I must be sucking up water. I did empty out the water separator but it still didn't make a difference. It was running fine when the tank was full on the prior trip and this time I ran it down real low.<br /><br />My main question is, if the tank is full wouldn't I still see the ill effects of water in the fuel or does it get pulled into the system when the level of fuel goes down?<br /><br />I appreciate any suggestions, I've been wrenching on cars, motorcycles, and boats for 30 years + and I can't seem to pin point this problem.
<br /><br />Thanks for any help, sorry for the long post.<br /><br />P.S. Anyone have any good suggestions as to how to drain the gas tank? Considering a siphon but not sure if I can get it all the way to the bottom.
