Troubled carb settings 86 merc 3.7
New2boater
Got a boat for free it starts up and idles fine but as you throttle up fast it Boggs down and dies. If you throttle up slowly and I mean slowly it will rev up then die anyone have any insight on factory carb settings i.e. Air fuel screw
Bt Doctur
fuel filters
clogged idle circuits
clogged hi speed circuits
Does not sound like a simple mixture adjustment unless someone cranked the screws all the way in.
From LIGHTLY SEATED, open them 3-4 turns and see.
welcome aboard
free boats are the most expensive boats in the world. Think about it, if there was any value in the boat, you wouldnt have gotten it for free. and one of the worst free boats you can get is one with the 3.7 motor.
most likely your accelerator circuit is needing help. either the accelerator pump is shot, or the circuit is plugged
with any new to you boat, make sure to do all the maintenance:
gimble bearing
raw water pump
alignment
bellows
u-joint check
gear lube replace
engine lube replace
fuel filter replace
cap/rotor/wires/plugs
in addition to that, with the 3.7
pressure test the exhaust manifold
pressure test the engine
inspect the cam seal
compression test
