I am trying to get electronics working on this boat. I do lots of wiring, but new to boats. Motor runs fine. Pumps and electronics (GPS and Fish finder) have no power. I just figured out there are panel circuit breakers below the switches, but they are not popped.
Confirmed that the bilge pump is alive using direct 12V connection. Aux power (lighter connector) has power at the panel. I am thinking there is a master breaker under the panel, but so far, I see nothing. Hard to see over the gas tank, but the connections generally do not look terribly corroded.
I found a wiring harness diagram for CRI DX-hull Model, that looks very close to what I have. I am about to pull the panel, but worried about the screws being loose when I replace it, if I do that.
Any ideas? Thanks,
Tom in VA
Any ideas? Thanks,
Tom in VA
