Troubleshooting your engines starting system
Status
Not open for further replies.
Don S
So you hit the ignition switch to start the engine so you can go home and either nothing happens, or you here a click from the engine, but the starter doesn't crank......... Now what????<br /><br />If you have a test light, you can find out in only a few minutes what the problem is. I like test lights because they are faster and easier to use than a meter. A meter will also work fine for all the tests if you know how to use it.<br />Here is what I call a test light, even Wal Mart sells them for less than 5 bucks.<br /><br />
Fig 1<br /><br />I will start by assuming you have a good battery, clean tight connections with good battery cables of the proper size. If you have loose, corroded cables and connections the following tests are a waste of time.<br /><br />So, where do you start looking for your no start condition? That depends on what you hear when you turn the key. If you DO NOT hear a click, we will start at the ignition switch, if you hear a click, we will head for the engine compartment.<br />Let's say we have no click, and the shifter is in the neutral position and we have already tried wiggling the lever to be sure it's in neutral.<br />Grab your test light and head for the back of the instrument panel. Hook the clip to a good ground (usually on the fuse panel).<br />Now, touch the light to the B terminal on the ignition switch ( big red or red/purple wire) the test light should light. Now move the test light to the S terminal with the yellow/red wire and have someone turn the key to the start position. The test light should light, if not, you need a new ignition switch.<br />Let's say it lit up, so the switch is good. While the problem could be the neutral safety switch, it's a real pain to get to in order to test it. So let's check to see if we have power going through the neutral safety switch.<br /><br />
Fig 2<br /><br />Time to head for the engine compartment. <br />Now, locate the slave solenoid on the engine. Notice the 4 wires to it? <br /><br />
Fig 3<br /><br />Hook up your test light again with the clip on a good ground. Now touch terminal C of the slave solenoid with your test light and have your helper turn the key to the start position again. The light should light up? If it did, touch your test light on terminal A, if it lights, hook your test light lead to it, and put the probe on terminal D (the ground) if it doesn't light, then you have a bad ground for the slave solenoid and without that ground the slave solenoid will not work.<br />If the test light did not light up, then the problem is 1 of 3 things either the connection at the main engine harness plug is bad, or you have a bad neutral safety switch or a bad connection between the ignition switch and the slave solenoid.<br />If you are at home, this isn't a problem and you can track the problem down. But if you are out on the water what can you do???? Simple. Use a test lead on the slave solenoid to jump between terminals A and B or A and C and the engine will crank. Make sure the ignition switch is in the run position and the engine will start.<br /><br />Ok, lets say when you hit the switch you hear a click from the engine, but no cranking of the starter. Now what do you check.<br />Simple, back to the slave solenoid on the engine. Hook up your test light clip to a good ground and touch the tip to terminal A, if it lights, touch it to terminal B and have your helper hit the starter switch again. If you hear a click and the light does not come on, then the problem is a bad slave solenoid. If you are out and need to start the engine, you can disconnect the wires from terminals B and C and hook them together and you will be able to bypass the slave solenoid all together and it should work. If not, due to long wire runs, just jump between terminals A and B to crank the engine over.<br />If the light does come on, move on to the starter solenoid itself. <br /><br />
Fig 4<br /><br />Touch terminal B on the starter solenoid itself, if the test light lights up, then you have a problem with the starter itself. Time to pull the starter and have it tested, repaired or replaced. If you are out on the water, you may be able to tap the solenoid (Gently, don't want to break things) while holding the switch to the start position and see if it will work. If not, you need a tow.<br /><br />One other thing to keep in mind when checking with a test light or a meter either one. Check the terminal of the unit itself and also check the wire at the terminal. A corroded or loose wire end could also be the problem.<br /><br />While this may sound like a lot of work, it only takes a few minutes to check things out.<br /><br />These pictures are all from a Mercruiser manual, mostly because they are available. OMC works the same, although their slave solenoid is a different kind, Volvo uses a relay instead of a solenoid, but again, it works the same way.
prockvoan
Re: Troubleshooting your engines starting system
Great info!When is class #2?Always looking to learn more,thanks.
Wotknot
Exxxxxxcellent work, Don. Geez, that oughta get us .....errrrrr, I mean you lots of donations coming my way.
Great Post,............<br /><br />JB's Got to put this 1 in the FAQ section......
Ralph 123
Second that Bondo - this needs to be put in the FAQ
lowshovel1
Thanks for taking the time to set that up for us---I for one, do apreciate it!
Peter J Fraser
DonS,<br />You have been watching a lot of the recent posts.<br />Good work on the above post, you have it explained VERY clearly.<br />I agree with Bondo, needs to be moved to FAQ's.<br /><br />Peter
cosander
Don S you rock... thanks dude
Destin
Excellent ideas. I like to add an extra 3 foot wire with an alligator clip to the probe end of the test light so that I can use either probe or clip. That way I can attach one lead to ground and the other lead to whatever I am testing, and place the light where it can be seen from the helm. No need for a helper to check out the starter or tilt and trim circuits. I can see the light from 30 feet, can't read a meter that far away.
KM2
Thanks a bunch Don for the graph. It help me solve a nagging starting problem this weekend. <br />What a relief!<br /> :) <br />Turns out the igition wire was bad somewhere between the plugs. Fished a new wire in there and it works great. For the first time in year I have confidence it will start on the first turn of the key.
Limited-Time
Every time a see a post started by Don S it's an automatic MUST READ. Another outstanding post Don.....Thanks a bunch.
imported_scott_m
Thanks, I'm going thru this exact process on my Wellcraft next time I'm at the marina...I'm in the turn the key, no click club.<br /><br />Don, you happen to work much on Onan generators?
RandyJ
Master Chief Petty Officer
DON S...great post!!! Right now I've got my big bayliner rigged with a horn button to bypass the switch and safety neutral. Frequently I can crank it over once with switch then if it doesn't stay running I can try it again with the key and nothing! not even a click. I've done everything to check and everything checks out but it still doesn't always work...like it gets hot after the first try and loses conductance. So, I bootstrapped the "emergency" start button to get me by until I can figure it out. Since it is a 1976 and was in salt I kinda assume it has a corroded safety neutral...hmmmm, where can I get another one of them thangs?
flablonde
Thanks alot for the help and diagrams, I'll get it right this time! Have a great thanksgiving!<br />Laura
Richard Petersen
Thanks for helping a lot of people Don. Seeing you do this warms my heart. Thanks again.
Status
