harringtondav
- May 26, 2018
- 2,473
Reassembling again this year after replacing the gear yoke and seal I noticed it was loose again. I redid the Loctite using 271 red for the heck of it. But I also ordered a new shaft.
My worry is the shaft slides loose for the last 1/2" and presses the first part with just my fingers on the press jack. Seems to indicate the bottom of the pinion bore is over size. If the new shaft also loosens I'll have the shell out for a new upper gear set. Ouch.
Any theories why this shaft loosened? The fretting corrosion is visible in the pic. Bearings have always looked great.
Also any recommendations on a better retaining compound when I press (hopefully) in the new shaft?
