try again,95,60hpmariner,very weak spark,soon to be boat anchor
Dan Kratzer
S.N.- 0g150191 spark to weak to start motor,all cylinders the same.any ideas would be appreciated.tournament coming soon
madecool
Re: try again,95,60hpmariner,very weak spark,soon to be boat anchor
There are several ways to improve the spark. I list some of the easy ways on most common engines. Because I don't know how your engine is. So just some basic for now. I sure you get some more replies. Some things to check are Spark plug wires if you can replace these they are not much and will usually help a little if the one you have on there now are really old but if you can't just replace them make sure they are not rusted inside the boot where it connects to the plug if so you might have to replace that and coil because they might be connected. All wire plugs connection that come from the power pack into the coils should have a good dry connection. Inspect the coils there should be good insulation on the wires and if the coils ground wire should have a good connection the coils should be inspected for anything that might seem to make them bad. Of course new spark plugs will help. You could check to make sure you are not shorted anywhere to. Inspect the with your eyes is the best to start see if you find a problem. Try and see if it is a enough to get it to run.
