flintdiver
- Jul 25, 2011
- 12
Ok so 1st off I bought this engine and was told it was a 25hp or 35.The cowling sticker was torn off.On the sticker on the side of mounting bracket it says mfg part# aml35d So any help on that would be great. Now ,the main issue I'm having is the engine cranks and idles perfect.When I give it a little gas ,its fine.When I twist on it to plane, it sometimes will jump on plane then bog till it nearly quits or bog as soon as the throttle is accelerated.Now when it does this I can adjust my palm over the carb opening a certain way,and it runs full throttle fine.But I have to adjust my hand perfect.What is going on here?The carb has been gone thru and cleaned thoroughly.I have new fuel in the tank. ????Please help!!! thank you
