I have a 1990 Johnson VRO 140. Been trying to get it started since i got it back from the mechanic. Can't seem to find anything I did differnt;y exceot he used his kill switch and I don't have one. He said I need to get one after I got i back. But I thought that I could just find a way to hold the button down. Anyway he said is has good compresion 125,125,125,130. He said it was runnin fine and i had him disconnect the vro so I can run premix. I can't get the **** thin gto start have prime and primed but won't start. I called him and he said the only thing that he could think of was me not having a kill switch. I have pressed it down though when I try to start it and it just cranks but no fire although smoke does come out the exhuast. I also noticed gas coming out behind the prop?? Normal? Water came out to but my mecahnic said that was normal as well. I have checked fuel lines and the bulb does get hard before starting. I am thinking about disconnecting the kill swith. I have a solid black and 2 black with a yellow stripe going into it. I hard is I cut those then I won't have to worry about it any suggestions. It was running well when he had now I can't get it to work. Oh after i got mad I tilted it back up and gas was coming out of some hle it looks like toward the middle of teh engine before the carb was that just from the angle?? Sorry for being so long.
