harleyman1975
Ensign
- May 12, 2003
- 959
2003 Regal 2000 (20') bowrider 2 8' 6" beam 3400 lbs dry 40 gal tank I/O 305 2 bbl mercruiser Alpha one gen max hp offered 280
normally 4-6 ppl primary use is pleasure (not much skiing or tubing) Deep Vee 20 degrees of deadrise 1.5 ratio
4400-4800 WOT range
no tabs or hydrofoil Quicksilver Nemesis Propeller Black Finish, 14 dia x 19 pitch, Right Hand
RPM _4600__________ Speed ___47________ No. of people _____2_______ Gal. Gas ___20_____
1100' elevation no damage to prop engine running perfect tuned up 20 hrs ago
put current prop on to improve hole shot and bring rpms up into suggested range (with 14.5x21 3 blade only turning 4350 WOT 48 mph)
Will 19x3 al give more top end? would stainless make a difference? anything I can do to improve holeshot ? (short of more horsepower or bravo 3)
4400-4800 WOT range
