gatorgitter
- Mar 31, 2008
- 19
Howdy All...
I'm trying to remove my '03 VP SX-M drive to check the bellows, gimble and ujoints.
I have the factory outdrive manual...I have the access cover, shift linkage and retaining clamp, trim clylinders (aft pivot pin ) ,and all 6 nuts removed. I have a home made stand/cart , which will support the outdrive by the spray plate.
My problem is that when I try to pull the outdrive off, it won't budge ( much) . I've tried shaking it, putting pressure/pulling on different angles, etc. , but I can only get ~.5mm crack to show. I assume it's is held on by corrosion. Although it doesnt look Too bad, imo, it was a salt water drive for a few years , and it looks to have never been removed.
I'm afriad to try to pry it loose, drop it / shake it harder, etc, and just as scared to hook my ATV up to it ( I got that idea elseware on this forum
Any advise or ideas? Will soaking the crack w/BPBaster help , or hurt ? I've read a post about hooking up the trim cylinders and giving it a bump, but I think I'll have to brace the gimble housing , and I dont want to bend/break anything...
I can post pics if it will help, but my bet is that somebody has dealt w/a stuck outdrive before...
Thanks for any/all advise...
gator
gator
