Re: Tune-up Help
Three blade, vented, stainless steel Mirage Plus prop and you'll get what you want. 3 bladers will give you the higher top end you want at the expense of the better hole shot that a 4 blade will provide. As for prop strikes, you can get a solid or rubber hub. The rubber will not save the prop from a possible reman, but it is designed to save the driveline. Look for them online and get the best price you can. Mercury's prices are $650 plus.
As for long time boaters...aluminum all the way. It's cheaper, breaks when it hits a stump or rock, can be remaned fairly cheap, and...well, top end is not a particular concern for the most part. I have always had SS on my boats but that's because I buy my boats to do what I want them to do. I'm not a boat engineer and everything I have every heard of family runabouts/sport boats is that all the performance is in the original engineering unless you're adding oarlocks to the gunwales.
