Re: Tune up Manual in PDF format
You should get a manual that explains the whole process. It should be done in conjunction with a link and sync on the carbs. If mixture is set incorrectly, worse case scenario, you can melt a piston, or on the other hand it will run too rich which will foul plugs. If you're trouble-shooting some type of an idle problem, then you should start with a compression test and an ignition test.
