I have a 1979 70hp and i am new to outboard motors but not new to motors.<br />lets just say this: it has a rebuilt fuel pump, and the carbs were cleaned and new kit put into them, new plugs, new gas, and the compression is about 110+- cold<br />if i have a too rich of an idle mixture would the fuel build up in the crankcase at all?<br />there is no fuel leaking when it runs or if i squeeze the bulb but after it idles for a while and i shut it off it will drip a little from the center throttle shaft.<br />it has a rough idle but i just figured 2 strokes are a little rough.<br />The floats are adjusted to 11/16 like the manual i have states. and it does not overflow (i don't think)<br />the floats are not new but they look ok.<br />i did check the idle mixture but i did not want to lean it out too much (i know thats bad for 2 strokes)<br />any thoughts?
