Turbo Charge Mercruiser Engine??
pwrplay
Hey, has anyone done or seen it done, turbo charging a Mercruiser 5.7 L engine in an express cruiser?
Are/Would there be any benefits? Would it be hard to do?
Just thought I'd throw it out there to see if it is even feasible.
bomar76
Re: Turbo Charge Mercruiser Engine??
Old news....pretty much been abandoned.
Banks and other used to sell kits, really not a good way to go on a boat, superchargers (Procharger for one) are 100X easier to install.
Google them up.
pwrplay
This topic is more out of curiosity than anything else. I am of the type to keep it stock and reliable then mess around and have problems.
What are the difficulties with Turbo Chargers?
Are the Superchargers reliable?
Limited-Time
Heat, effective RPM range, and the dreaded turbo-lag all come to mind.
pwrplay
Thanks for the info guys. I'll just keep my boat stock. LOL
HT32BSX115
Turbo lag would not really be a problem on a boat I would think.....
With a "wet" exhaust it would absolutely be a challenge though. I know a guy in Ca that put a 400 small block and belt driven blower in his Bayliner .... It's probably easily 450 hp! . It's in front of an Alpha though .....(I hope he doesn't "straight-arm" it!!)
It's FAR easier to do a belt driven supercharger than it is to to do an exhaust driven supercharger because of the unique exhaust requirements of a enclosed marine engine. It wouldn't be a problem in a boat with an exposed engine.
QC
It's the exhaust piping for a turbo that make it both a hassle and a fire hazard . . . :eek: To do it properly you would need wet piping from both manifolds, to some space where you'd mount the turbo and then back to the Y pipe from the turbo exhaust outlet, or pipe that through transom. Plus you need a water cooled turbine housing. All a problem if not factory. I agree that turbo lag is not that bigga deal, especially with a cruiser.
Ayuh,......
If you look Long,+ Hard you can find systems just as described by QC,....
Water cooled manifolds, water cooled turbos,+ wet risers to dump everything out the back......
I've seen them for both SBCs,+ BBCs.....
I've been rat holing all the pieces to do a dry exhaust turbo'ed Jetdrive for years now,.....
'course,... About All I'm lacking is the Time to put it all together.......;)
